NR7101 vs iphone 5g speed
But NSA with all other settings to auto?0
NSA works fine with all auto and also with pci lock and band settings
But speed without pci lock?0
speed in any setting never over 200mit
cpu limt in NSA mode ?
My speed in NSA is 250 DL with poor connection.
300+ DL with 4G advanced.
i had a talk with german telekomthere is no 5G-SA in my areathey aproved: there are no limitations on my SIM card
but unaproved, there might be some qos depending on enddevice in use.
so ether there is qos on provider side or nr7101 does not support NSA as good as iphone.
is there a way to fake or change IMEI on the nr7101
You must have a SA in your area because you did a PCI scan.
It´s not possible to do that with NSA.....
Set to SA and fill in your fields like i did.... Also set NR28 in band management......
Don´t forget to click Apply.
Do a reboot and see whats happen...
https://www.cellmapper.net/arfcn?net=NR&ARFCN=156510&MCC=222
set NR5G-SA / ps only (and reboot)then i tried band 28 , 78 , 3500but i get this error ( and after reboot no success )0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
