NR5101 control via Webside
Fremmed
Fremmed Posts: 4 image  Freshman Member
edited January 2024 in Mobile Broadband
Just installed NR5101 wi-fi router. Got access to the system via LTE Aly. Cannot access by website with correct login.
Why?
  • Miaa
    Miaa Posts: 28 image  Freshman Member
    First Anniversary
    Hi Fremmed, my NR5101 with firmware 100ABVC4C0 and my mobile phone connect to NR5101's WiFi can access to device via Zyxel Air App. You may download Zyxel Air App from App Store or Google Play. I hope it will help you.
  • Fremmed
    Yes, LTE Ally works more less ok (means that you don’t have total overview of your router).
    The problem now is with website login.
    192.168.1.1 doesn’t work.
    Its impossible restore password.
    What is wrong?
  • samthing
    samthing Posts: 1 image  Freshman Member
    Was having the same issue and realised the solution was to login to the nebula dashboard which displays the password in Site-wide > General settings > Device configuration.
    Not sure why this password is different from the one on the label. Rather annoying.
