NWA50AX standalone - minimum requirement for seamless roaming of clients?
Dear Customer
Roaming is the behavior of clients handle with the difference AP. With the good AP deployment, seamless roaming exists.
802.11k/v will help APs through Ethernet get information about neighbor APs/SSID then share to the clients.
Zyxel_Judy
A compatible network controller and the support of 802.11k, r, v
Hi Bellocarico,
This FAQ shows you how to set up seamless wireless roaming in Controller mode: How to Set up Seamless Wireless Roaming? — Zyxel Community
You also can enable Fast roaming settings by click on 802.11r.
Zyxel_Judy
Bellocarico said:I like Nebula but to be fair I find the standalone interface more practical for my usage.There's one question I have though... what do I need to enable (in standalone) for multiple wired AP to talk to each other and share client information so that clients can roam seamlessly between APs? I don't see anything on the interface apart from fast roaming but it still doesn't tell me if and how the devices communicate amongst each other.Thanks!0
Zyxel_Judy said:
Hi Bellocarico,
This FAQ shows you how to set up seamless wireless roaming in Standalone mode: How to Set up Seamless Wireless Roaming? — Zyxel Community
mMontana said:A compatible network controller and the support of 802.11k, r, v
jpblanch75 said:Bellocarico said:I like Nebula but to be fair I find the standalone interface more practical for my usage.There's one question I have though... what do I need to enable (in standalone) for multiple wired AP to talk to each other and share client information so that clients can roam seamlessly between APs? I don't see anything on the interface apart from fast roaming but it still doesn't tell me if and how the devices communicate amongst each other.Thanks!
I do have fast roaming and each device see each other in the Overview - Ethernet neighbor. Is it safe to assume devices peer to each other to share client information and make fast roaming happen? Or is a network controller really needed?
Bellocarico said:jpblanch75 said:Bellocarico said:I like Nebula but to be fair I find the standalone interface more practical for my usage.There's one question I have though... what do I need to enable (in standalone) for multiple wired AP to talk to each other and share client information so that clients can roam seamlessly between APs? I don't see anything on the interface apart from fast roaming but it still doesn't tell me if and how the devices communicate amongst each other.Thanks!
I currently use Nebula with fast roaming enabled and it works fine. In standalone mode you couldn't enable fast roaming so I'm wondering if that option has been added. That's my question.0 -
Dear customer,
There is no fast roaming (802.11r) as an option in standalone mode, just 802.11k/v.
Zyxel_Judy
I do have fast roaming and each device see each other in the Overview - Ethernet neighbor. Is it safe to assume devices peer to each other to share client information and make fast roaming happen? Or is a network controller really needed?Dear Bellocarico,
It is okay if you would like to make roaming in standalone mode. To ensure the roaming can be used, please:
l/ Keep at least 15% to 20% overlapping coverage for APs nearby.
lI/ Same SSID name and Security settings.
Note here:
• Roaming is a mechanism for a client to connect to the other access point while remaining connected to the network, so you don’t need to do any configuration.
• Client will roam automatically when signal goes lower than a value.
• If there’s no same SSID nearby, client will keep connecting in bad signal until can’t receive it anymore.
Zyxel_Judy
Zyxel_Judy said:Bellocarico said:jpblanch75 said:Bellocarico said:I like Nebula but to be fair I find the standalone interface more practical for my usage.There's one question I have though... what do I need to enable (in standalone) for multiple wired AP to talk to each other and share client information so that clients can roam seamlessly between APs? I don't see anything on the interface apart from fast roaming but it still doesn't tell me if and how the devices communicate amongst each other.Thanks!
Note here:
I'm very familiar with roaming, please note the title of this thread clearly specifies:seamless roaming
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
