NR7101 Poor throughput (No 5GNSA ?). Confused with Firmware versions
Maximum 15 minutes....1
Hello @k1s
What is the current modem firmware installed in your NR7101?
(Figure 105 in the user guide will show you where to find out.)
It might be that you already have version 06 and that you need version 07.
Also, are the modem firmware names the same otherwise?
I hope that this is helpful.
Kind regards,
Tony
Hi folks,
I've just bought my first NR7101 and I am hitting what sounds like a similar issue to this.
I can't see any version reported in "Current LTE Module Version" (whether with SIM or not). Trying the Module Upgrade (via ethernet) doesn't seem to do anything: the screen appears to be loading, I leave it for more than 30 minutes and the screen is still loading...
I'm now on "Current Firmware Version: 1.00(ABUV.4)C0". (I upgraded to this from v.2 that the router came with). Originally, the module worked because I could get connectivity to the internet - but not more than 100mbit, and my phone could do 400+ mbit on the same speedtest right next to the zyxel. However, it is not the firmware upgrade that caused the LTE module to stop working, because it did work even after the upgrade.
If anyone has some ideas / thoughts about what I can try, please let me know!
Thanks in advance!!0 -
Check your LAN cable if it is 1000/Full or just 100. I had the same poor speed as you because of the ethernet cable, dont know if it is your problem.....
Log in and go to main page.
Hi Tony, the current modem and LTE module firmware are (top of the first post):tonygibbs16 said:What is the current modem firmware installed in your NR7101?
Current Firmware Version: V1.15(ACCC.0)C0
Current LTE Module Version: RG502QEAAAR11A03M4G
Not sure what you mean by this?:
I'm using the files kindly linked by @SELBERG :tonygibbs16 said:Also, are the modem firmware names the same otherwise?SELBERG said:1 -
Thanks,
I the meantime, ZyXEL tech support came back and gave this download link:
https://www.dropbox.com/s/kix4g50eehbsyp8/RG502QEAAAR11A06M4G-RG502QEAAAR11A07M4G.zip?dl=1. They said to install that straight over version R1103. I did, and sadly instead of improving performance it seems to have made it even worse.Nearest Three UK Mast <1km 44Mpbs down 1Mbps upBand n78 RSRP -91 RSRQ -12 SINR 3Access Technology NR-NSA EN-DCBand LTE_BC3 UL Bandwidth (MHz) 15 DL Bandwidth (MHz) 15RSSI -54 RSRP -89 RSRQ -18 TAC 1736 SINR -8 CQI 8 MCS 1 RI 2 PMI 0Band LTE_BC1 RSSI -68 RSRP -93 RSRQ -16 SINR -32nd Three UK Mast <1km 35 Mpbs down 1Mbps upBand n78 RSRP -92 RSRQ -15 SINR 11Access Technology NR-NSA EN-DCBand LTE_BC1 UL Bandwidth (MHz) 10 DL Bandwidth (MHz) 10RSSI -58 RSRP -87 RSRQ -13 SINR 4 TAC 1392 CQI 9 MCS 0 RI 2 PMI 16Band LTE_BC3 RSSI -58 RSRP -79 RSRQ -11 SINR 2etc.Can anyone here think of why such poor performance compared with an indoor router standing on the roof achieving 3-10x faster connections?0 -
can you make a chart with ookla speedtest
nr7101 vs. 5G mobile phone vs. 5G indoor router
I also have performance issue
In my case the modem module firmware version did not appear until the SIM was inserted, then robooted AND then connected to the internet
I discovered that even upon successful upgrade the browser window simply doesn't refresh. It seems you can see if the upgrade worked after 15 minutes by duplicating the browser tab and logging in again
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
