How Can we activate recognition of the dnsft.cloud.zyxel.com certificate to enable access to youtube
leasba
leasba Posts: 5 image  Freshman Member
The browsers do not recognize the dnsft.cloud.zyxel.com certificate, they give it to me as invalid and it prevents my network users from connecting to youtube. How Can we activate recognition of the dnsft.cloud.zyxel.com certificate to enable access to youtube.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,350 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    edited September 2022 Answer ✓
    Hi @leasba
    After our discussion on the eITS, this issue was caused by the specific security policy on your site. You solved it by yourself. Thanks :) .
  • Zyxel_Jeff
    Hi @leasba
    When the user cannot access YouTube is there any blocked or dropped message that can be observed on the eventlog(Firewall > Monitor > Event log)?
  • Zyxel_Jeff
    Hi @leasba
  • Carlsap
    Carlsap Posts: 23 image  ZCNE Certified
    First Comment Seventh Anniversary ZCNE Security Level 1 Certification - 2019 ZCNE Nebula Level 1 Certification - 2019
    What is the resolution in this case?
  • Hi @leasba
    What was the solution? We are having same problem with Youtube, Vimeo and all other streaming media platforms.
Nebula Tips & Tricks
