lte7490-m904
Marcoloi1988_
Salve,
devo creare una vpn tra USG FLEX 700 server e un lte7490-m904.
grazie
grazie
Marcoloi1988_ said:Salve,
grazie
Using Google Translate, I read that you want to
"Greetings,i need to create a vpn between USG FLEX 700 server and a lte7490-m904.thank you"
Looking at the User Guide, available to download from https://www.zyxel.com/global/en/products/next-gen-firewall/usg-flex-firewall-usg-flex-700 , chapter 19 then it seems like you would need a pair of USG FLEX 700 devices to run an IPSEC VPN between them, or one if you are setting up an SSL VPN.
- The LTE7490-M904 would be the access to the mobile network as the underlying bearer over which the VPN would be carried.
I hope that this is helpful.
Ciao Tony0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
