NBG6515 timing out for 1 second couple times a day dropping all connections
OGO
in Home Router
NBG6515
drops all wifi and ethernet connections at random intervals for a split-second, multiple times per day. Youtube/Twitch and Online gaming stops, then restarts. I tested the ethernet connection directy to the internet modem for 1 month, bypassing NBG6515 and I had no issues.
I did master reset on Zyxel and did not fix.
I did firmware upgrade today on Zyxel and did not fix.
The log on 10.0.0.1 router site, does not show any anomaly/event in last two hours though I just had the network connection flicker and kick me of Twitch and gaming.
How do I fix this? Do I just throw away the Zyxel router and get another brand? Seems like I have tried everything. It flickers the connection and then continues as if nothing, but ruins online gaming, and connection that need to be constantly consistent.
Have you ever check the log on the NBG6515?
Do all of the clients under NBG6515 have the same disconnection issue?
Hello, It seems i have the same issue with my NBG6515. At the moment i am using my the
V1.00(AAXS.9)C0 firmware.
So it seems when i do online gaming in the 5GHz Wi-Fi the connection drops out. Windows 10 just shows no connection and it takes a few seconds for it to come back available again. This is very weird. I did a reset pressing it 15 seconds and setup the router again. Something seems to be wrong with it i am not sure what's going on.0 -
What games are you playing?Playing other games would have the same symptom?
Maybe the issue only happens on Windows but other device works.
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
