I want to set up my Multy M1 without creating a cloud acct.
Nbh
I want to set up my Multy M1 without creating a cloud acct. I also would like to access the router configuration without internet access, but for some reason this seems to be the ONLY router ive purchased in 20 years that wont take me directly to the config menu without internet access. Please advise me if i need the cloud acct(extreemly intrusive)so i can decide if i need to return this product. If I can log into a cisco router without internet access and a cloud acct, I should be able to log into yours.
Hi @Nbh
To complete the installation, it requires creating a cloud account.
Currently,Multy M1 needs to register an account for the app using.
After registering an account, it will ask to set up a local password, then when log WEB GUI, there are two login type can choose, cloud account login and local password login.
You can choose local password to login device.
You can refer to the article to complete the installation.
https://community.zyxel.com/en/discussion/13713/multy-m1-installation#latest
Zyxel_Jerry said:To complete the installation, it requires creating a cloud account.
Glad to know; this requirement automatically qualify the device as a "no go" for most cases.
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 482 News and Release
