Multy U app
Carsten_Sørensen66
Best Answers
Hi @Carsten_Sørensen66
Please check if your app version is using Testflight version or the Multy APP version.
If you're using the Testflight version of Multy APP, if you have a registered account on myZyxelCloud, you can remove the app and install the Multy APP in the APP store.
With a registered account, the configurations are saved in myZyxelCloud.
Please use the latest version and add other multys again, it should work without any problem on the latest app version.0 -
I tried two times more and everything is now up and running. Have a good day0
I am using testflight so that i could use an earlier build. But i still cannot add other multys or control anything.0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
