WAN Backup configuration for lte5388-m804
romanomauro
romanomauro Posts: 1
edited January 2024 in Mobile Broadband
Hi, I am trying to configure this LTE router to have a backup connection to an ASUS DSL-N55U.
Unfortunately I can't get it to work, does anyone have a guide or experience to share on this?
What I did:
1) Enabled WAN on LAN1 port
2) Network cable from Zyxel (WAN) to Asus (LAN)
2) Set IP 192.168.2.1/255.255.255.0 on ethernet interface in Zyxel
3) tried to disable all firewalls.
Asus is connected to the internet via WAN / USB / LTE and exits on the internet via Zyxel. But when Zyxel loses the connection it doesn't pass the command to Asus.
I have dealt with multiple ways but I don't find the right one.
Thank you,
Mauro
  • Bob_C
    Bob_C Posts: 222  Master Member
    Hi Mauro,
    Does the ASUS DSL-N55U have a fail-over/fall-back design?
    I think it should determine which WAN interface has connection and which does not so that fail-over/fall-back between the main interface and the back-up interface (e.g. Zyxel LTE5398) can happen.
    Regards,
    Bob
