Nas 540 broken after power-outage
Well, so far it has copied 73MB, without detecting some sectors could not be copied. When you are lucky, the problem is mainly on the start of the disk. If not, it will takes 10 years before you know if the result is usable at all.
Hello Fever!,
hey all!
I have nearly the same problem after using Rescue Stick. The Header Checksum ist bad.
I have access to barebox, network and tftp-server.
But how can I update my kernel (nand0.kernel2.bb) with tftp? The folder "dev" is mounted readonly and I get an error message. I tried different uImages. When I use the update kernel command it shows an error "there is no nand0.kernel2.bb partition in file". Thanks for answer in advance. Bernd
- 588 USG FLEX H Series
- 476 News and Release
