LTE5398-M904 - Sms inbox bugs and unreadable messages
androll
Hi, I wrote to report many disfunctions in sms features of LTE5398-M904 device.If I try to open android app Zyxel Air in sms section, the app immediately crashes and closes.Many sms received from my italian operator (WINDTRE) are impossible to read because they appear only as an extremly long series of letters and numbers without sense.
Firmware would be the last: V1.00(ABQV.2)C0
There is a way to recover sms unreadable and solve problems?
And in the end, there is no way to save sms in an external storage as USB drive but only inside SIM card, with the result of only 11 messages storage capacity... if I put SIM inside a phone to extract and save messages the card results empty!!I think is necessary to improve functions becasue at the moment sms features are very very bad and almost impossible to use.
Could you please contact Zyxel support team?
This case might need some remote troubleshooting sessions, and I think it'd be better to handle this case by ticket.
Contact Support | Zyxel Networks
Regards,
Bob0 -
Bob_C said:Hi,
Regards,
Bob
Do you have some news on it, maybe with an updated fw that already fixed it, or do I have to contact Support too?
Regards
hi, i have the same problem with vodafone operator (italian). i can't recive or send SMS. have you resolved?
With the last ABQV.3 firmware and with updated Zyxel Air app you can see that SMS continue to be codified inside web gui but they are readable inside app.
It Is not elegant or the best solution but it works.
You check new messages inside web GUI and after you can read inside app.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
