ATP200 firmware update impossible
Peppino
Peppino Posts: 182 image  Master Member
First Comment Friend Collector Seventh Anniversary
I have an ATP200 with the following fw versions installed in the flash:
Upgrade of any of these banks is impossible since either trying over FTP, or HTTP, after the upload of 532ABFW0C0.bin is finished, the serial console drops a Firmware not compatible! message.
Can you please advise how can I overcome this situation?
  • Peppino
    I have also tried with 5.30(ABFW.0) version, but the result was the same...
    PeterUK Posts: 4,302 image  Guru Member
    edited November 2022
    Maybe try run standby firmware then update it?
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,568 image  Zyxel Employee
    Hi @Peppino,
    Please follow steps below to update firmware.
    1) Backup partition 2(current running partition) startup configuration file.
    2) Reboot on partition 1.(Switch running partition from 2 to 1)
    3) Update V5.32 firmware on partition 1.
    4) Apply 1) configuration file on partition 1.
  • Peppino
    Hi @Peppino,
    Thank you, it worked! What is causing this?
  • Zyxel_Cooldia
    Hi @Peppino,
    It could be related to firmware corruption on running partition.
