ATP200 firmware update impossible
I have an ATP200 with the following fw versions installed in the flash:
Upgrade of any of these banks is impossible since either trying over FTP, or HTTP, after the upload of 532ABFW0C0.bin is finished, the serial console drops a Firmware not compatible! message.
Can you please advise how can I overcome this situation?
I have also tried with 5.30(ABFW.0) version, but the result was the same...0
Maybe try run standby firmware then update it?
Hi @Peppino,Please follow steps below to update firmware.1) Backup partition 2(current running partition) startup configuration file.2) Reboot on partition 1.(Switch running partition from 2 to 1)3) Update V5.32 firmware on partition 1.4) Apply 1) configuration file on partition 1.0
Thank you, it worked! What is causing this?Zyxel_Cooldia said:Hi @Peppino,Please follow steps below to update firmware.1) Backup partition 2(current running partition) startup configuration file.2) Reboot on partition 1.(Switch running partition from 2 to 1)3) Update V5.32 firmware on partition 1.4) Apply 1) configuration file on partition 1.0 -
- 603 USG FLEX H Series
- 481 News and Release
