Zyxel – Multy M1 - problems with wifi connection
b46664
b46664 Posts: 1 image  Freshman Member
edited November 2022 in Multy WiFi System
Please, I need a help.
I have Zyxel – Multy M1 and all my devices which are connected to it with a wifi, regularly are loosing wifi (they are 2 meter far from the router). I have found something about "logging" in my router settings and I have no idea what does it mean.
Thank you for your help!
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    Hi @b46664
    As the log shows, the internet seems disconnected every 9 minutes on Nov 15th.
    Please check your ethernet cable connect correctly, or try with another cable.
    Please send us feedback on the Multy APP.
    The Enabled logging on this page means recording the log on Multy M1, if you disable it, there would be no logs show on this page.
