Lte5398-M904 latest firmware (actual is v1.00(ACBQ.0)b6 ITALY
vgkit
vgkit Posts: 3 image  Freshman Member
edited January 2024 in Mobile Broadband
I Have just purchased LTE5398-M904, could I have the latest firmware update fot Italy with cell lock ?
  • Bob_C
    Bob_C Posts: 222 image  Master Member
    Hi vgkit,
    Please contact Wind Tre for this case because it's up to them if any new firmware can be released.
    Regards,
    Bob
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @vgkit
    Christophe @CTOLZANE pointed out that there is the V1.00(ABQV.2)C0 firmware available for download from https://www.studerus.ch/fr/support/downloadcenter even if it is not on the Zyxel website.
    You might still want to contact Wind TRE to confirm that you are ok to use it as Bob @Bob_C suggests.
    Kind regards,
         Tony
  • Shinjisan73
    Shinjisan73 Posts: 6 image  Freshman Member
    Hi, I updated the router with the FW. VER..V1.00 (ABQV.4) C0, and the "VOLTE" telephony function with Windtre no longer works.How can I do to solve the problem?Can I downgrade the device fw or put another version of FW?
    Thank you.
    Greetings.
  • Shinjisan73
    edited August 2024
    Hi, I wanted to add this information of the installed LTE module:
    Quectel
    EG18
    Revision: Eg18eapar01a12m4g
    How do I do to return to the original Zyxel version "Eg18eapar01a08m4g? Thanks.
    Greetings.
  • Shinjisan73
    Hi, I don't remember what the previous version was, I'll recover the data and let you know.
    Greetings.
  • Shinjisan73
    I found the version, the one I had previously was "V1.00(ACBQ.0)b6".I continue to have problems with the "VOLTE" I did a factory reset and it started working again but after a long period of the device being unused,
    I turned the router back on and the VOLTE no longer works.Strange thing. I don't know if there is any update available.
