NR5103e rebooting every few hours
tfh
tfh Posts: 2 image  Freshman Member
edited January 2024 in Mobile Broadband
I have had a NR5103e for a couple of weeks now and it has never managed more than 36 hours of uptime before rebooting. On average it reboots about every 12 hours. When it does so the network is only down for about 5 mins but it is frustrating nonetheless.
The firmware on the router is V1.00(ACBJ.0)b10.
I have turned logging on and there are some telling errors just before each reboot, which I do not see in log files produced when no reboot has occurred. It looks like unhandled errors on the low-level communication interfaces.
Here is a copy of the kernel errors in all.log file, either side of the reboot.
Nov 17 12:47:27 kern.err kernel: swapper/0]mtk_soc_eth 15100000.ethernet: generated random MAC address f6:63:ad:f4:66:1b
Nov 17 12:47:27 kern.err kernel: swapper/0]mtk_soc_eth 15100000.ethernet: generated random MAC address 0a:8b:e4:d1:80:7a
Nov 17 12:47:27 kern.err kernel: swapper/0]netif_napi_add() called with weight 256 on device
Nov 17 12:47:27 kern.err kernel: swapper/0]bmp380 i2c_trans err:76 76 (0 0000000023a2b9ef 1) -121
Nov 17 12:47:27 kern.err kernel: swapper/0]bmp380_check_chip_id fail(0x 0).
Nov 17 12:47:27 kern.err kernel: swapper/0]bmp380 chip id mismatch,exit probe!
Nov 17 12:47:27 kern.err kernel: swapper/0]bmp380_probe fail!
Nov 17 12:47:27 kern.err kernel: swapper/0]i2c i2c-2: Failed to register i2c client slave_charger at 0x5b (-16)
Nov 17 12:47:27 kern.err kernel: swapper/0]i2c i2c-2: of_i2c: Failure registering /i2c2@11c42000/slave_charger@5b
Nov 17 12:47:27 kern.err kernel: swapper/0]i2c i2c-2: Failed to create I2C device for /i2c2@11c42000/slave_charger@5b
Nov 17 12:47:27 kern.err kernel: swapper/0]mtk-msdc 11230000.mmc: init hardware done!
Nov 17 12:47:27 kern.err kernel: swapper/0]mtk-msdc 11230000.mmc: host->mclk:0, ios->clock:400000, host->timing:0,ios->timing:0
Nov 17 12:47:27 kern.err kernel: swapper/0]mtk-msdc 11240000.mmc: init hardware done!
Nov 17 12:47:27 kern.err kernel: swapper/0]mtk-msdc 11240000.mmc: host->mclk:0, ios->clock:400000, host->timing:0,ios->timing:0
Nov 17 12:47:27 kern.err kernel: kworker/2:1]mtk-msdc 11240000.mmc: host->mclk:400000, ios->clock:0, host->timing:0,ios->timing:0
Nov 17 12:47:27 kern.err kernel: kworker/2:1]mtk-msdc 11240000.mmc: set mclk to 0
Nov 17 12:47:27 kern.err kernel: kworker/1:1]mtk-msdc 11230000.mmc: host->mclk:400000, ios->clock:400000, host->timing:0,ios->timing:9
Nov 17 12:47:27 kern.err kernel: kworker/1:1]mtk-msdc 11230000.mmc: host->mclk:400000, ios->clock:200000000, host->timing:9,ios->timing:9
Nov 17 12:47:27 kern.err kernel: kworker/1:1]mtk-msdc 11230000.mmc: host->mclk:200000000, ios->clock:200000000, host->timing:9,ios->timing:1
Nov 17 12:47:27 kern.err kernel: kworker/1:1]mtk-msdc 11230000.mmc: host->mclk:200000000, ios->clock:52000000, host->timing:1,ios->timing:1
Nov 17 12:47:27 kern.err kernel: kworker/1:1]mtk-msdc 11230000.mmc: host->mclk:52000000, ios->clock:52000000, host->timing:1,ios->timing:10
Nov 17 12:47:27 kern.err kernel: kworker/1:1]mtk-msdc 11230000.mmc: host->mclk:52000000, ios->clock:200000000, host->timing:10,ios->timing:10
Nov 17 12:47:27 kern.err kernel: swapper/0]proslic_spi spi3.0: mtk_ext_spi_probe()
Nov 17 12:47:27 kern.err kernel: swapper/0]mt6880-audio 11210000.mt6880-afe-pcm: mt6880_afe_enable_clock()
Nov 17 12:47:27 kern.err kernel: swapper/0]mt6880-audio 11210000.mt6880-afe-pcm: mt6880_afe_runtime_resume()
Nov 17 12:47:27 kern.err kernel: swapper/0]mt6880-audio 11210000.mt6880-afe-pcm: mt6880_afe_runtime_suspend()
Nov 17 12:47:27 kern.err kernel: swapper/0]mt6880-audio 11210000.mt6880-afe-pcm: mt6880_afe_gpio_init(), ret -19, cannot get aud_pinctrl!
Nov 17 12:47:27 kern.err kernel: swapper/0]mt6880-audio 11210000.mt6880-afe-pcm: init gpio error
Nov 17 12:47:27 kern.err kernel: swapper/0]mt6880-audio 11210000.mt6880-afe-pcm: mt6880_afe_pcm_dev_probe()line 3973
Nov 17 12:47:27 kern.err kernel: swapper/0]mt6880-audio 11210000.mt6880-afe-pcm: mtk_afe_combine_sub_dai(), num of dai 48
Nov 17 12:47:27 kern.err kernel: swapper/0]Error: Driver 'proslic_spi' is already registered, aborting...
Nov 17 12:47:27 kern.err kernel: swapper/0]PROSLIC_API ERR: proslic_spi_setup(637): spi_register driver returned = -16
Nov 17 12:47:27 kern.err kernel: swapper/0]Si3218x_Init_with_Options(641) size = 1 init_opt = 0
Nov 17 12:47:27 kern.err kernel: swapper/0]Si3218x: register 0 read = 0x00
Nov 17 12:47:27 kern.err kernel: swapper/0]Si3218x: : failed to detect any ProSLICs
Nov 17 12:47:27 kern.err kernel: swapper/0]mt6880-audio 11210000.mt6880-afe-pcm: Control not supported for path ETDM_PCM0_MUX -> [PCM] -> ETDM Capture
Nov 17 12:47:27 kern.err kernel: swapper/0]mt6880-audio 11210000.mt6880-afe-pcm: ASoC: Failed to add route ETDM_PCM0_MUX -> PCM -> ETDM Capture
Nov 17 12:47:27 kern.err kernel: swapper/0]mt6880-audio 11210000.mt6880-afe-pcm: Control not supported for path ETDM_PCM1_MUX -> [PCM] -> ETDM Capture
Nov 17 12:47:27 kern.err kernel: swapper/0]mt6880-audio 11210000.mt6880-afe-pcm: ASoC: Failed to add route ETDM_PCM1_MUX -> PCM -> ETDM Capture
Nov 17 12:47:27 kern.err kernel: swapper/0]mt6880-audio 11210000.mt6880-afe-pcm: ASoC: no source widget found for AP_DMIC_CH34_EN
Nov 17 12:47:27 kern.err kernel: swapper/0]mt6880-audio 11210000.mt6880-afe-pcm: ASoC: Failed to add route AP_DMIC_CH34_EN -> direct -> AP DMIC CH34 Capture
Nov 17 12:47:27 kern.err kernel: swapper/0]mt6880-audio 11210000.mt6880-afe-pcm: mt6880_add_misc_control()
Nov 17 12:47:27 kern.err kernel: kworker/2:1]mtk-pcie 11288000.pcie: PCIe link down, ltssm reg val: 0x1
Nov 17 12:47:27 kern.err kernel: kworker/2:1]mtk-pcie 11290000.pcie: PCIe link down, ltssm reg val: 0x1
Nov 17 12:47:27 kern.err kernel: kworker/2:1]mtk-pcie 11298000.pcie: PCIe link down, ltssm reg val: 0x1
Nov 17 12:47:27 kern.err kernel: kworker/2:1]mtk-dsi 1400e000.dsi0: Failed to get system config registers: -19
Nov 17 12:47:27 kern.err kernel: kworker/2:1]mediatek-drm 14000000.mmsys_config: mtk_drm_kms_init
Nov 17 12:47:27 kern.err kernel: kworker/2:1]mtk-dsi 1400e000.dsi0: failed to add component: -22
Nov 17 12:47:27 kern.err kernel: swapper/0][DEVAPC]: get_permission: cannot get sys_index & ctrl_index
Nov 17 12:47:27 kern.err kernel: kmodloader]conninfra@(platform_request_firmware:537) failed to open or read!(conninfra.cfg)
Nov 17 12:47:27 kern.err kernel: kmodloader]conninfra@(conninfra_conf_init:586) read conninfra.cfg file fails
Nov 17 12:47:27 kern.err kernel: kmodloader]consys emi memory address gConEmiPhyBase invalid
Nov 17 12:47:27 kern.err kernel: kmodloader]conninfra@(msg_thread_send_wait_3:456) [msg_thread_send_wait_3] can't get free op for 0x2
Nov 17 12:47:27 kern.err kernel: kmodloader]conninfra@(conninfra_core_thermal_query:1316) send msg fail ret=-1
Nov 17 12:47:28 kern.err kernel: kworker/3:2]5_VBUCK1: couldn't disable: -1
Nov 17 12:47:28 kern.err kernel: kworker/3:2]5_VBUCK3: couldn't disable: -1
Nov 17 12:47:28 kern.err kernel: kworker/3:2]vmd12: couldn't disable: -5
Nov 17 12:47:28 kern.err kernel: kworker/3:2]vrfdig: couldn't disable: -5
Nov 17 12:47:28 kern.err kernel: kworker/3:2]vmd11: couldn't disable: -5
Nov 17 12:47:28 kern.err kernel: kworker/3:2]vsram_md: couldn't disable: -5
Nov 17 12:47:28 kern.err kernel: kworker/3:2]vsim1: couldn't disable: -5
Nov 17 12:47:28 kern.err kernel: kworker/3:2]vaux18: couldn't disable: -5
Nov 17 12:47:28 kern.err kernel: kworker/3:2]va12_2: couldn't disable: -5
Nov 17 12:47:28 kern.err kernel: kworker/3:2]vmddr: couldn't disable: -5
Nov 17 12:47:28 kern.err kernel: kworker/3:2]vmddq: couldn't disable: -5
Nov 17 12:47:28 kern.err kernel: kworker/3:2]va12_1: couldn't disable: -5
  • Bob_C
    Bob_C Posts: 222 image  Master Member
    Hi tfh,
    Please contact Three's support team for this case; they should receive direct feedback from end users, and if there's anything that Zyxel needs to do, Three will contact Zyxel.
    Regards,
    Bob
  • tfh
    Hi Bob,
    Thanks for getting back to me. Since posting I have been in contact with Three and they have told me that this is a known issue with this model of router and are working with Zyxel to resolve.
    Hopefully a resolution will come soon.
    Tom
