NR2101 keeps restarting even after reset
fboleto
My NR2101 keeps restarting for no reason, the only way to stop is to take the battery out.
It is running the latest firmware:
Zyxel Firmware version:
(V1.00(ABUS.4)C0
Software version:
RXLG1.27.00.232_0R03
MiFi Software version:
AXDG1.27.00.194_0R03
Trying to upgrade from: https://support.zyxel.eu/hc/en-us/articles/4404106191890-NR-5G-Series-Troubleshooting
https://www.dropbox.com/s/ohue7spm3t1ab0k/NR2101_2C000_3C000.zip?dl=0
Gives the error:
It only happens when a sim card is inserted, without it, is working correctly ( I have tried two different providers).
This forum is not allowing me to post a video of it (only images), Amazon ( where I bought it) does not offer support, and Zyxel Europe does not allow me to open a ticket.
I don't understand why I cannot get any support on such an expensive device.
(V1.00(ABUS.4)C0
Software version:
Gives the error:
Does it restart intermittently i.e. after 10-20 seconds of operation or does it go into a boot loop?
Try running the device without battery with the provided charger and see if that works.
Taking the battery out and connecting it directly to the charger has the same behavior.
I got a replacement, and .... exactly the same problem with the second device. It seems that this device does not like Portuguese 5G networks. When no sim card is inserted it never restarts, when a sim card is present and it connects to a 5G network it restarts.
To my surprise the mobile operator store, said that they don't advise or sell this equipment anymore since the same problem is happening to them.
Zyxel should really fix this, they will lose customers by selling very expensive devices that do not work. A simple firmware update would be ideal, but by looking at the date of the last firmware update, it tells me that no effort is being put into it.0 -
Hello @fboleto
I have been looking at the NR2101 user guide available at https://support.zyxel.eu/hc/en-us/articles/4403365084818-5G-Devices-Advanced-Downloads-Firmwares-and-other-resources- to see if there is anything in there to help.
Under the APN, is the PDP set for IPv4 or IPv6 or IPv4 and IPv6 ?
- it might be worth seeing if changing this setting changes the behaviour...
Since the reboot happens with a SIM inserted then I can only think that it is related to when it tries to activate the PDP context on the APN.
Do you have a SIM card that only supports 3G and 4G to see if it is related to the connection to 5G WWAN only or not?
These are just some thoughts from someone who is a Zyxel user.
- I hope that they are helpful.
Merry Christmas.
Kind regards Tony0 -
Hello Tony,tonygibbs16 said:Hello @fboleto
Merry Christmas.
Kind regards Tony
Thank you for your suggestion, I am afraid that did not solve the problem. I now have only ipv4, with a manual apn, but the problem still exists.
I am also having the same issue and found if I disable 5G and only use 4G the network is stable and the router does not reboot.
If I enable 5G it will start rebooting every 20 seconds roughly.
I had this router for just over a week and this did not happen so not sure why it started all of a sudden, I am on latest firmware V1.00(ABUS4)C0Appreciate if anyone has further troubleshooting steps.
I got mine exchanged with a new one under warranty at Zyxel Cystomer Support.
- 3K Nebula
- 222 Nebula Ideas
- 618 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
