NAS 542 Twonky Server not reachable via 9001 port
oh yes, thanks to your comments I see what the problem is:I have two network interfaces on the NAS (with two network cables), one has the address 192.168.1.101, the other 192.168.1.102.With the lsof command, we can see that twonky is listening on port 9001 in localhost and also on the 192.168.1.102 interface but not on the 192.168.1.101 interface.
twonkyser 1913 root 4u IPv4 5347 0t0 TCP 127.0.0.1:9001 (LISTEN)<br>twonkyser 1913 root 5u IPv4 5348 0t0 TCP 192.168.1.102:9001 (LISTEN)<br>twonkyser 1913 root 6u IPv4 5349 0t0 UDP 192.168.1.102:1900 <br>twonkyser 1913 root 7u IPv4 5351 0t0 UDP 192.168.1.102:49001 <br>twonkyser 1913 root 9u IPv4 5352 0t0 UDP 239.255.255.250:1900 <br>twonkyser 1913 root 10u IPv4 5353 0t0 UDP 192.168.1.102:1030 <br>
the nmap command show the 9001 port not open on 192.168.1.101 but that's right open on 192.168.1.102However, in the management panel there is an explicit reference to http://192.168.1.101:9001 :<table><tbody><tr><td colspan="3"><div>Activer Twonky Media Server</div></td></tr></tbody></table><div>Pour la désactivation, le serveur de médias va arrêter les services photo, musique et vidéo, et également désactiver leurs icônes sur l'écran d'accueil.</div><div><div><div>État et réglage:<a rel="nofollow" href="http://192.168.1.101:9001" title="Link: http://192.168.1.101:9001">http://192.168.1.101:9001</a></div></div></div>
Translated with www.DeepL.com/Translator (free version)
Hi @sitro
Thanks for the feedback.
The twonkyserver IP on NAS would always select Port 1 IP as the server IP address.
If the LAN Port 2 get the IP address before Lan Port 1 get the IP address, then the pages on the Control Panel > Service > Media Server > Media Server would still keep the Lan port2 IP which get the IP firstly on this page.
We'll have an enhancement on this.
Best Regards,
Jerry0 -
Hi guys, is it possible to ask a question here, about Twonky server? The problem is still the same: Twonky doesn't work on port 9001.
I did a control in windows → NAS property and the port is the 10243 (see image attached).
Last but not least, my NAS is new (well, I re bought a 542 after electric failure of the old one).
Hi @ceramassimiliano68
To check the issue further, I have PM you, please check your message box.0 -
I have the same problem as ceramassimiliano68. Tonky is on port 10243 not 9001. using LAN2 only
Please advise me how to change it back to port 9001
When you remove Lan2 but only leave Lan1, will the port not available to access?
- 588 USG FLEX H Series
- 477 News and Release
