One folder completely disappeared after reset!
jazzkovacs
Hi!
I have hard reseted my NAS 326 recently, and when I logged back in, one of my folders just disappeared. No trace of it on the device whatsoever.
Note, that this wasn't one of the default folders, like "Music, Video, Photo", it was a separate folder, created by me on the same folder level where those defaults are.
Where did my folder go? And WHY???
Any chance to retrieve my precious data?
Fingers crossed, praying for someone to help me out!
Laszlo
Laszlo
It's still there. It only lost it's status as 'share', because that is a part of the user config. Now it is just a directory. To get it back you have to go to the shares menu, and re-enable it.
Reset the NAS will not remove the data on the disk0
Mijzelf: The folder appears to be there, but it's empty (see screenshot).
Dexter: Yep, it shouldn't, this is why I was surprised, that everything disappeared.
I just can't explain this, nor retrieve my precious files.0 -
According to the 'unmount' buttons, and the description 'Remote Volume' this is a screenshot of a client with mounted shares. But it's the server who decides what will be shared. So you have to login to the webinterface of the NAS and turn the directory into a share.
Mijzelf said:According to the 'unmount' buttons, and the description 'Remote Volume' this is a screenshot of a client with mounted shares. But it's the server who decides what will be shared. So you have to login to the webinterface of the NAS and turn the directory into a share.0
I did this.
You enabled the share in Control Panel->Privilege and Sharing->Shared Folders?
YOU ASK WHAT YOU DID WRONG? YOU BOUGHT A F...G ZYXEL PRODUCT. THAT IS WHAT YOU DID WRONG. I reset to factory because for no reasons I was not anymore able to access web interface after fw update, and after reset all my shares where gone. Data seem to be inside disks but no way to access them via old, re-enabled or newly created shares on the disks. This crap creates issues by itself.0
After resetting the NAS, the files should still in the disk, however, if you create a new volume, the data will be erased.
How do you access your web interface, by the domain or IP address?
You can check the IP above your router to know which IP address your NAS gets.
It seems you have access the NAS, how do you access the web interface?0
- 435 Beta Program
- 176 Nebula Ideas
- 119 Nebula Status and Incidents
- 430 USG FLEX H Series
- 299 Security Ideas
- 79 Switch Ideas
- 276 Service & License
- 427 News and Release
- 89 Security Highlight
