How to set up a static IP address for a client device via Web GUI?
Zyxel_Support
Zyxel_Support Posts: 436 image  Zyxel Employee
edited September 2018 in Multy WiFi System
Step 1: Access the Web GUI with a web browser.
  • Open a browser such as Chrome, Firefox, Safari and so on.
  • Type http://zyxelwifi.comhttp://zyxelwifi.net or http://192.168.212.1 (default IP address) in the address bar of the browser.
    In order to be able to access the Web GUI, you might have to get the correct IP address which is assigned from the router if your Multy Plus (WSQ60) is in bridge mode.
Step 2. Log in with your myZyxelCloud account.
Step 3: Click the "Menu" icon.
Step 4: Find and expand "Settings" in the menu list and click "LAN".
Step 5: Add a new rule.
  • Click Add Another Rule.
  • Select your device from Device List.
  • Modify IP Address with a static IP address to reserve this IP address for the device.
  • Click the APPLY button to save the setting.
  • fabrialare
    fabrialare Posts: 12 image  Freshman Member
    Hi
    i follow your instructions and in the access list i put the flag on reserve ip too
    that in any case put a rule inside the table of LAN ip
    the problem is after a while i will find the lan ip table empty
    the router deletes the rules on his own why?
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,401 image  Zyxel Employee
    Hi @fabrialare
    Here is a new article you posted, we can discuss the issue here.
