NAS540 Bootloop, then Upgradekey, now Nothing
Thanks for the walk-through. Do you have a theory how the uImage in flash could be damaged?
Mijzelf said:Thanks for the walk-through. Do you have a theory how the uImage in flash could be damaged?
I used these lines in usb script to solve bootloop. Now nothing, just system led On. Any info?
ubiattach -m 3 -d 3
mount -t ubifs ubi3:ubi_config /etc/zyxel
cd /etc/zyxel
rm -r *
I'm in the same situation with a 540.
I had automatic reboot, I updated to last version and I'm in bootloop.
I removed disks.
I reset with back Button, 2 beeps, nothing changed.
I read about reset deleting the settings folder. I prepared usb key with yours command lines.
Now the nas stays ON, system led White, but not responding to Nas Seeker, no reset button (no beeps), no power button.
I can power it off just disconnecting power cord.
Any tips?
I'm afraid that it gets stuck in the bootloader. Without serial connection you can't do anything about that. (And with maybe neither, depending on the actual problem.)
Hey there Fefe,
I think you have to log in via serial to check the screen output, like Mijzelf suggested. I would've never found the solution without that.
After you did that, you can follow my steps in the answer to this post.
Sorry but I have now the same problem with my NAS542. I downloaded the "NAS540_521AATB3C0_Upgradekey" of Mijzelf, but the led red appears and the device don´t do it, nothing and reboot again.
When you tall about "serial connection" what do you meant? I´m very lost with the solution.0 -
Here is a wiki about (using) the serial port on a router:
For a NAS it's basically the same. Just another embedded Linux box.
I've never done anything like this. Let's see what I can learn from the link you sent me. Thank you so much.
Although I don't know if I'm going to be able to do anything with a device that reboots every few seconds. At Zyxel they don't give me the chance to send the equipment in for repair. They say that it is an EOL and that I have to buy a new one.0
- 434 Beta Program
- 174 Nebula Ideas
- 411 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 268 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 82 About Community
- 87 Security Highlight
