Which socket do you plug the UPS monitoring cable in to?
4yawbontva
There are various USB ports on my NAS542 device. I plugged the monitoring cable from the APC CS500 UPS into the NAS but it is not detected. Is there a specific port I should use? (I should add I'm confident it's not the device or cable since they work elsewhere.)
Today's lesson - it doesn't matter which port on the NAS you use if the data cable isn't plugged in to the right port on the UPS. I'll get my coat...
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 436 News and Release
- 91 Security Highlight
