Slow 5G speeds with NR5101
If n78 is a standalone, just change to NR5G-SA and check, don't disable any band.
My worry with selecting NR5G as the preferred access technology is that it will lose connectivity if for whatever reason it cannot connect to 5G as I suspect it is only connecting to the 4G bands. I'll wait until I'm near the 5101 again before I try this otherwise I think I'm going to have to send it back and purchase a different 5G router like the D-Link DWR-2101SELBERG said:If n78 is a standalone, just change to NR5G-SA and check, don't disable any band.
Hi all,
Vodafone said that their 5G network in the UK was being 5G standalone from July 2022, see https://www.vodafone.co.uk/newscentre/smart-living/everything-you-need-to-know-about/5g-everything-you-need-to-know/#:~:text=So%20including%20the%20UK%2C%20we,or%20in%20its%20Core%20network.
- from 2019 until 2022, Vodafone 5G in the UK had been Non Standalone Access (NR-NSA).
So if you want just Vodafone 5G network only, then I think that you have to select NR5G.
- but if you want the best of 4G and of 5G including NR-NSA then I think auto is it.
Zyxel even recommend Auto and Auto for access technology and band selection, see https://support.zyxel.eu/hc/en-us/articles/4404106191890-NR-5G-Series-Troubleshooting#h_01GKVJQBWM5WKG0VPTYA2D56RJ
Happy New Year.
Kind regards,
Tony0 -
But i think it is better just add n78 in band technology and check speed.....0
I tried selecting NR5G at the preferred access technology and the NR5101 went offline (flashing red light):
have put back to auto and enabled band auto selection and suddenly much better speeds 250mb (although still not 500mb). This is the signal info now:NR-NSA InformationMCC234MNC15Physical Cell IDN/ARFCN628032Bandn78RSRP-65RSRQ-12SINR34Service InformationAccess Technology5G NR-NSA EN-DCBandLTE_BC8RSSI-34Cell ID4208140Physical Cell ID365UL Bandwidth (MHz)10DL Bandwidth (MHz)10RFCN3624RSRP-65RSRQ-14RSCPN/AEcNoN/ATAC24723LACN/ARACN/ABSICN/ASINR6CQI13MCS17RI3PMI32PSCN/ASCC Information# 1Physical Cell ID233RFCN2850BandLTE_BC7RSSI-57RSRP-78RSRQ-9SINR8# 2Physical Cell ID393RFCN323BandLTE_BC1RSSI-48RSRP-70RSRQ-11SINR8
I'm worried when the router next restarts it'll go back to the 4G / 70mb speeds again so will keep a close eye on it before I return it.1 -
Maybe you need to buy a poynting x-pol 2 outdoor antenna.
The NR5101's external antenna and device ability support 3300-4200 MHz.
So you might get higher speed with that.1 -
Just seems crazy that I need to use an external antenna when I'm only 30 metres away in clear plain sight from the mast.SELBERG said:Maybe you need to buy a poynting x-pol 2 outdoor antenna.
I have a couple of spare Cisco 4G/3G Omnidirectional Dipole Antennas (4G-LTE-ANTM-D) would that also receive a 5G signal or no? Full spec: https://www.cisco.com/c/en/us/td/docs/routers/access/wireless/hardware/notes/4G3G_ant.html
I'd need to use some SMA to TS9 adapters0 -
I used the Zyxel Air app and repositioned the NR5101 to a different window and now getting better speeds:
NR-NSA Information MCC 234 MNC 15 Physical Cell ID N/A RFCN 628032 Band n78 RSRP -55 RSRQ -11 SINR 372
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
