Slow 5G speeds with NR5101
If n78 is a standalone, just change to NR5G-SA and check, don't disable any band.
SELBERG said:If n78 is a standalone, just change to NR5G-SA and check, don't disable any band.
Hi all,
Vodafone said that their 5G network in the UK was being 5G standalone from July 2022, see https://www.vodafone.co.uk/newscentre/smart-living/everything-you-need-to-know-about/5g-everything-you-need-to-know/#:~:text=So%20including%20the%20UK%2C%20we,or%20in%20its%20Core%20network.
- from 2019 until 2022, Vodafone 5G in the UK had been Non Standalone Access (NR-NSA).
So if you want just Vodafone 5G network only, then I think that you have to select NR5G.
- but if you want the best of 4G and of 5G including NR-NSA then I think auto is it.
Zyxel even recommend Auto and Auto for access technology and band selection, see https://support.zyxel.eu/hc/en-us/articles/4404106191890-NR-5G-Series-Troubleshooting#h_01GKVJQBWM5WKG0VPTYA2D56RJ
Happy New Year.
Kind regards,
Tony0 -
But i think it is better just add n78 in band technology and check speed.....0
I tried selecting NR5G at the preferred access technology and the NR5101 went offline (flashing red light):
have put back to auto and enabled band auto selection and suddenly much better speeds 250mb (although still not 500mb). This is the signal info now:NR-NSA InformationMCC234MNC15Physical Cell IDN/ARFCN628032Bandn78RSRP-65RSRQ-12SINR34Service InformationAccess Technology5G NR-NSA EN-DCBandLTE_BC8RSSI-34Cell ID4208140Physical Cell ID365UL Bandwidth (MHz)10DL Bandwidth (MHz)10RFCN3624RSRP-65RSRQ-14RSCPN/AEcNoN/ATAC24723LACN/ARACN/ABSICN/ASINR6CQI13MCS17RI3PMI32PSCN/ASCC Information# 1Physical Cell ID233RFCN2850BandLTE_BC7RSSI-57RSRP-78RSRQ-9SINR8# 2Physical Cell ID393RFCN323BandLTE_BC1RSSI-48RSRP-70RSRQ-11SINR8
I'm worried when the router next restarts it'll go back to the 4G / 70mb speeds again so will keep a close eye on it before I return it.1 -
Maybe you need to buy a poynting x-pol 2 outdoor antenna.
The NR5101's external antenna and device ability support 3300-4200 MHz.
So you might get higher speed with that.1 -
SELBERG said:Maybe you need to buy a poynting x-pol 2 outdoor antenna.
I have a couple of spare Cisco 4G/3G Omnidirectional Dipole Antennas (4G-LTE-ANTM-D) would that also receive a 5G signal or no? Full spec: https://www.cisco.com/c/en/us/td/docs/routers/access/wireless/hardware/notes/4G3G_ant.html
I'd need to use some SMA to TS9 adapters0 -
I used the Zyxel Air app and repositioned the NR5101 to a different window and now getting better speeds:
NR-NSA Information MCC 234 MNC 15 Physical Cell ID N/A RFCN 628032 Band n78 RSRP -55 RSRQ -11 SINR 37
2
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
