New deployed nwa55axe shows ups as Wireless Bridge
vining
vining Posts: 26 image  Freshman Member
edited November 2023 in Nebula
in NCC, Access Points > Configure > AP & port settings as Wireless Bridge. Is this normal?  I just added it via the Nebula app and I just want it AP mode, I'm trying to bridge anything.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Zyxel Employee
    Hi @vining,
    We found the same the symptom as you shared, and it should be a display problem, so we’ll fix it and tell you when it is done.
    Please refer to status of Wireless bridge at Access point > Monitor > Access point > AP information page > Status > Wireless bridge before we fix problem.
    Please note that the status of Wireless bridge as Enable at Access Points > Configure > AP & port settings doesn’t affect to the AP mode and the AP still can broadcast SSID.
    Thank you for this input.
    Zyxel_Judy
    Untitled Image
  • vining
    thanks, I had looked under monitor > AP > Status and there wireless bridge shows off so it made no sense.  As long as its just a gui bug and nothing functional I can live with it.
  • Zyxel_Judy
    Hi there,
    We fixed the issue already.
    When users add NWA55AXE into Nebula, Wireless Bridge is Disable as defautl at Access Points > Configure > AP & port settings and Access Points > Monitor > Access points > AP information page > Status. The Wireless Bridge status will be changed (Enable/ Disable) if users have new configuration.
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
