L2tp vpn remote connection
Capriwebdesign
in Nebula
Hi there, form today i have this problem, a client told me that the remote connections on the mobile phone don't work, i have a ikev1 onthe firewall that is usgflex 100 nebula mode, is in nat configuration, so, a week ago all work wonderful, but now not work, the mobile phone says (please upgrade a ikev2 vpn mode) but if i try a configure ike v2 on my phone i can't put my user and password, but only the shared key. so how i can resolve? i need a configure new vpn gateway, or i can upgrade only the ikev1 to ikev2 from the firewall and phone without change too many configuration?
Android stupid reason and I guess no one see the point with user and password for ikev2 just if they have shared key your trusted.
yeah, but how i can resolve? and for apple is the same that you know?, if you says it to me, i must wait a android update? or i can have other mode to gige the remote connections to the users android?0
There's nothing you can do but use ikev2 without user and password option.
I don't have Android phone for testing but I thought you can use strongswan application instead of native ikev2.
Some one needs to do a ikev1 vpn app for Android0
Hi @Capriwebdesign,
Greeting Forum,
We will recommend using the ikev2 because it's more secure. Please kindly refer the link to complete ikev2 setting
Thank you
Kevin
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
