NAS326 Degraded Drive
My NAS326 had a fall so got an error message that Drive 1 degraded - I swapped Drive 1 out  for a new harddisk and thought it would then redo the Raid setup and copy Drive 0 onto the new Drive 1 and I could then replace the damaged Drive 0 with a new disc and everything fine again
I now get an error message saying Drive 0 degraded  - but the Storage Manager menu wont open to you can run the repair function.  A black box appears with the circle processing sign but nothing happens.
Any ideas on how to fix?
  • Mijzelf
    Mijzelf Posts: 2,982 image  Guru Member
    Are that the exact words? That is strange, as a disk cannot be degraded, only a raid array can.
  • Hi yes - that was the message.
    I now have bought two new nas drives do I copy all data onto one of the new ones and then put that in the zyxel with the other empty one and that will then automatically backup and make a new raid array
