firmware gs1910-24 & gs1910-24HP
2»
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,349 image  Zyxel Employee
    Hi @mMontana,
    The GS1910 series has special situation that it need to follow firmware upgrade flow.
    But other devices do not have upgrade flow to follow.
    That's why we only publish the latest firmware files of EOL devices on End of life | Zyxel.
    Zyxel Melen
  • mMontana
    mMontana Posts: 1,444 image  Guru Member
    I can respect the choice of not providing support for older devices.But be part of the process of not allowing an unpatched, sometimes buggy, sometimes unsure device "alone in a network" without posting into community appears to be another step to create more eWaste.
    Maybe wanted for sell more devices? IDK. But closing the FTP site still seems by a consumer and specialist perspective a step, but into the wrong direction.
    Give back to the customers the history of firmware, the documentation. For allowing more re-use of not "mint" hardware if necessary.
  • rkendall94
    rkendall94 Posts: 1 image  Freshman Member
    I just wanted to take a second and say thank you for uploading these files! I was able to get my switch updated from 1.00(AAAX.2) to 2.00(AAAX.0)
  • klaeuser
    klaeuser Posts: 6 image  Freshman Member
    I have a (rather old) GS1910-24 (without HP) and would like to upgrade the firmware.
    Can I use the files posted by https://community.zyxel.com/en/profile/Zyxel_Melen in December 2021 for that?
  • Zyxel_Melen
    Hi @klaeuser,
    Yes, you could use the firmware file to upgrade.
    Zyxel Melen
  • klaeuser
    thanks a lot, that worked perfect!
  • malteR
    malteR Posts: 1 image  Freshman Member
    Hi Melen,
    in the EOL List, there is no GS1910. Is the GS1910 EOL? Or is there a newer firmware as 2.00?
  • Zyxel_Melen
    Hi @malteR,
    It is because the GS1910 series switches reached end-of-life more than 3 years ago, please refer to the archived EOL product table here.
    Zyxel Melen
  • StefanZ
    StefanZ Posts: 202 image  Master Member
    First Comment First Answer Friend Collector Second Anniversary
    edited March 2024
    Sorry to dig up this old thread, but I just got a used GS-1910 on Firmware V1.00(AAAX.4).
    Could you be so kind to post the latest firmware possible, so I can upgrade?
    EDIT:
    OK, finally found it:
    Works like a charm.
