NWA50AX - Does not broadcast "guest" network
I can see/work with the normal SSID , but even when i select the "guest" network to broadcast, i cant see it on any of my mobile devices, its like its not broadcasting.
Any ideas on this?
Hi @CFlores
Please help us check if your NWA50AX’s firmware is updated to the latest version - V6.29(ABYW.1). You can see device’s current firmware at this direction: Site-wide > Configure > Firmware management, choose Devices tab. Also, you can choose ‘Upgrade now’ tab to upgrade device to the latest version.
Here is the FAQ of Firmware Management on Nebula https://community.zyxel.com/en/discussion/14582/nebula-new-firmware-management#latest, you can take a look at the FAQ to get to know more about functions as Firmware status, Firmware schedule,..
As showed on V6.29(ABYW.1)’s Release Note: https://download.zyxel.com/NWA50AX/firmware/NWA50AX_6.29(ABYW.1)C0_2.pdf, Layer 2 isolation and NAT mode have been recently added to this version, so if your current version is older than V6.29 that doesn’t support NAT mode, then the SSID enabled NAT mode would be invisible.
Best Regards
Nami
Nami
Hi @CFlores
Best Regards
Nami
Nami
Thank you very much, it was just like you said, it needed the latest firmware for the guest / nat loopback to function properly.
Kudos0
- 3K Nebula
- 229 Nebula Ideas
- 130 Nebula Status and Incidents
- 6.6K Security
- 661 USG FLEX H Series
- 359 Security Ideas
- 86 Switch Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 305 Service & License
- 497 News and Release
- 95 Security Advisories
- 5K FAQ
- 89 About Community
- 110 Security Highlight
