NR5103e loses internet connection once every 24h.
Robsjo
Hi!
I live in Sweden and use "Three" (3) as a mobile 5G provider.
I got the NR5103e mid September and it worked flawless for about a month. In mid October the swedish three support forum said they put out a firmware upgrade. After that the modem disconnects once every 24H. I tried IP passthrough, turned off DHCP. Etc etc. I even got a new modem from them but it is the same.
Currently awaiting answers from the support but they don't seem to have a solution.
In the system log on the Zyxel it says:
"APN-1 Disconnected"
Cheers.
Cheers.
Can you do a test, Home Networking/Lan Setup/DHCP Server Lease Time.
Try different values, 8 days and also shorter then 1 day, maybe 2 hours....0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
