Pair of XGS1930-28 w/VLANs advice?
My boss acquired two XGS1930-28 with the plan to put one in the cellar with the servers, one upstairs with the desktops, and the idea to run several of our internal networks across the connection with the help of VLANs.
Now I certainly understand IP networks, but I've never done anything with VLANs, and after reading up on the topic, my first attempts generally ended when I managed to configure myself off from the management UI. Clearly there's something I'm not getting.
In my last attempts, I tried to have a management-access network (a separate /24) going into port 24 on both switches (only one at first because I already learned that switching loops are a bad thing). Still, sooner or later I cut myself off. Maybe I'm going at it the wrong way entirely?
Any advice how I should set this up?
Simplified excerpt of our plans:
Note that currently, nothing here uses VLANs, though we'd like to eventually activate them on our router and perhaps also the VMware server so we can do more with fewer cables. But that's just for background, for now, I want to get the basics running.
- 10.0.99.0/24 to port 24 on both switches for management
- 10.0.15.0/24 has desktops on the upstairs switch, and our central router on our downstairs switch, plus our VMware server
- 10.0.17.0/24 has phones on the upstairs switch, and our central router on our downstairs switch, plus our VMware server
- No Nebula.
Hi @sps_kh,
I assume the VLAN of each subnet is:- 10.0.99.0/24 for VLAN 1, which is the management VLAN.
- 10.0.15.0/24 for VLAN 2, which use for PCs and VMware server.
- 10.0.17.0/24 for VLAN 3, which use for IP Phones that the IP Phone is VLAN disable.
Then you could reference the below example topology to setup the VLAN setting.
In addition, you could also reference this FAQ to setup the VLAN setting:
How to configure the switch to separate traffic between departments using VLAN — Zyxel Community
If your IP Phone is VLAN enable or you want to setup Voice VLAN, you could reference these FAQ:
How to configure the switch to separate VOIP traffic from data traffic — Zyxel Community
How to configure an IP phone's VLAN using LLDP-MED — Zyxel Community
How to configure Voice VLAN on Zyxel Switch — Zyxel Community
If there has any question, please feel free to ask.
Hope it helps.Zyxel Melen1
Hi @sps_kh,
- 3K Nebula
- 231 Nebula Ideas
- 6.6K Security
- 671 USG FLEX H Series
- 360 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 307 Service & License
- 500 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
