Nas542 Network problem
bulutnet
bulutnet Posts: 1 image  Freshman Member
Hello. I bought Zyxel Nas542. latest software version after using for a while
V5.21(ABAG.9)
I upgraded. I can't get pppoe connection after upgrade. It does not accept the process of reverting to the old version. I'm waiting for your help.
  • Mijzelf
    Mijzelf Posts: 3,074 image  Guru Member
    If you login over ssh (as root) and execute
    echo 1 > /firmware/mnt/info/revision
    you can downgrade by uploading a firmware file in the webinterface.
