need to change the IP address of a NAS326
rbabler
rbabler Posts: 4  Freshman Member
In moving and getting a new ISP provider I need to change the IP address of my NAS326 formaly set to the IP mask of 192.168.0.1 with a addrss of 192.168.0.150 the new provider's router has a address of 192.168.1.1 tried to change this many time with only greated with a error after entering the address information.
  • okimarukas
    okimarukas Posts: 92  Ally Member
    I think you can set the Na326 on the same subnet as your router. You can configure the NAS with the IP address 192.168.1.150, a subnet mask of 255.255.255.0, and set the gateway to 192.168.1.1.
  • rbabler
    Via instructions YES you are right “But have tried several times using the (startup Utility) and it fails to change the address!!” Looked at the setup optin but first step is it would wipe the drives HELL NO ON THAT . Am I going to put 2 different drives into the box run the setup Utl. to change the address then replace drives with my good ones? Is the address info stored on the drives or on a chip in the box???
  • Mijzelf
    Mijzelf Posts: 2,933  Guru Member
    The IP address and most of the other user settings are stored in a chip.
  • rbabler
    As Spectrum shows no ption to change IP addressing guess my only fix is replacing the supplied modem/router with a aftermarket one that defaults to the 192.168.0.1 net address. So have ordered one from Netgear.
