Nas326 password reset
MasN
MasN Posts: 1 image  Freshman Member
edited June 2018 in Personal Cloud Storage
I have lost my login informations. I tried to login via LAN to my Nas but it only says that username or pasword is incorrect. How can I reset password. I found some guide which told to press reset button 3 second. Would this work and can i be sure that my photos are still in safe? Please help.
#NAS_June
  • Ijnrsi
    Ijnrsi Posts: 254 image  Master Member
    You can press and hold the reset button till you hear one beep, then release the button.
    The admin's password will be reset back to "1234", and you can use admin/1234 to login web manage page.
    The program for password reset and full reset would not effect HDD's data, just config file restore back to default setting.
    Following is the reset behavior from NAS326's user manual.
  • ibo
    ibo Posts: 4 image  Freshman Member
    hi !
    i forgot my pass and i tried the reset button to reset the password, but surprisingly doesnot workig
    any ideas?
  • Batou
    Batou Posts: 101 image  Ally Member
    edited September 2019
    It should be worked after you press and hold the "HW reset button" till you hear one beep, then release the button. The admin's password will be reset back to "1234", and you can use admin/1234 to login web manage page.
    Please make sure that you press HW reset button and hear one beep, then release.
    Otherwise, you may need to reset the system to default.
  • kevin007
    kevin007 Posts: 1 image  Freshman Member
    I forgot my password.so i reset with reset button after one beep i release it.But no beep and can't connect with default ip.How should i do.
  • okimarukas
    okimarukas Posts: 92 image  Ally Member
    Not just pressing the button and release it, it required to press and hold the button for 3-5 seconds to hear one beep sound.
  • speak
    speak Posts: 1 image  Freshman Member
    reset 1 beep not working. ip address and password not reset
  • vargas1966
    vargas1966 Posts: 2 image  Freshman Member
    work. good thank u
