Plex on a zyxel nas326?
13
  • Yolo45
    Yolo45 Posts: 13  Freshman Member
    j'ai pas bien compris vous n'avez pas un tuto ?
  • Mijzelf
    Mijzelf Posts: 2,930  Guru Member
    Nope. I only have the instructions on zyxel.diskstation.eu. And apparently you have a French translation of that.
  • Yolo45
    je ne comprend pas comment télécharger ceci
  • Mijzelf
    You shouldn't need to. The web_prefix file tells the firmware package manager to use another repository, the one you listed above, and that package manager will download the files.
    Then, when MetaRepository is installed, it will change the web_prefix file again to point at itself.
  • Yolo45
    d'accord donc il faut que je récupére web_prefix mais ma question comment je le télécharge ? quand je clique sur web_prefix il m'affiche ça
    je doit faire quoi avec ce liens ???
  • Yolo45
    j'ai enregisté le lien sous
    mais ça me met un text
  • Mijzelf
    What do you mean?
  • Yolo45
    ça ma installé un document text
  • Mijzelf
    I see. When it's only the comment in the 'Type' column, it's no problem. After all, it is a text document. It contains only text. When there is a hidden '.txt' extension, that is a problem. Then you have to set the 'show known extensions' flag in explorer, and strip the extension.
    Sorry, don't have more details about that flag. It's several years ago I used a Windows system.
