Plex on a zyxel nas326?
j'ai pas bien compris vous n'avez pas un tuto ?
Nope. I only have the instructions on zyxel.diskstation.eu. And apparently you have a French translation of that.
je ne comprend pas comment télécharger ceci
You shouldn't need to. The web_prefix file tells the firmware package manager to use another repository, the one you listed above, and that package manager will download the files.
Then, when MetaRepository is installed, it will change the web_prefix file again to point at itself.
d'accord donc il faut que je récupére web_prefix mais ma question comment je le télécharge ? quand je clique sur web_prefix il m'affiche ça
je doit faire quoi avec ce liens ???
j'ai enregisté le lien sous
mais ça me met un text
What do you mean?
ça ma installé un document text
I see. When it's only the comment in the 'Type' column, it's no problem. After all, it is a text document. It contains only text. When there is a hidden '.txt' extension, that is a problem. Then you have to set the 'show known extensions' flag in explorer, and strip the extension.
Sorry, don't have more details about that flag. It's several years ago I used a Windows system.
- 441 Beta Program
- 292 Service & License
