NAS326 expanding from 2TB to 8TB... But never ending...
darekpawel
darekpawel Posts: 9 image  Freshman Member
Basically I had 2 x2TB HDD installed…
Few days ago replaced with 2 x 8TB. Of course first one disc, then the second.
Then followed the 'resync' advice… Went O.k.
So now was time for 'expanding' - started that - but it is already expanding for 5 days… And still continue…
What to do to finalize that?
  • darekpawel
    Update… Following instructions from other posts - problem looks to be solved…
    Thank you…
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    It shouldn't take that long. When the volume is clean it should only take a few minutes. I would reboot the box.
  • darekpawel
    Well… What do you mean 'clean'?
    It contains about 1,43TB of data…
  • Mijzelf
    Clean is about filesystem errors. As resizing of a filesystem is a delicate process, the box won't do it when there are filesystem errors. So it will first run e2fsck (checkdisk), and when that returns clean, or has repaired all errors, the actual resize is done. That resize only takes a few minutes. The running of e2fsck can take more, especially when errors have to be repaired. But not 8 hours.
  • darekpawel
    edited March 2023
    O.K. I did reboot… And started 'expanding' again… I'm affraid still the same… It is 'expanding' already over 1 hour… Looks like something is wrong.
    Here are some outputs (following advise from other posts):
    root@NAS326:/home/shares# cat /proc/mdstat
    Personalities : [linear] [raid0] [raid1] [raid6] [raid5] [raid4]
    md2 : active raid1 sda3[3] sdc3[2]
    7809895424 blocks super 1.2 [2/2] [UU]
    md1 : active raid1 sda2[3] sdc2[2]
    1998784 blocks super 1.2 [2/2] [UU]
    md0 : active raid1 sda1[3] sdc1[2]
    1997760 blocks super 1.2 [2/2] [UU]
    unused devices:
    root@NAS326:/home/shares# cat /proc/partitions
    major minor #blocks name
    7 0 144384 loop0
    31 0 2048 mtdblock0
    31 1 2048 mtdblock1
    31 2 10240 mtdblock2
    31 3 15360 mtdblock3
    31 4 108544 mtdblock4
    31 5 15360 mtdblock5
    31 6 108544 mtdblock6
    8 0 7814026584 sda
    8 1 1998848 sda1
    8 2 1999872 sda2
    8 3 7810026496 sda3
    8 16 3907018583 sdb
    8 17 131072 sdb1
    8 18 3906885632 sdb2
    8 32 7814026584 sdc
    8 33 1998848 sdc1
    8 34 1999872 sdc2
    8 35 7810026496 sdc3
    9 0 1997760 md0
    9 1 1998784 md1
    9 2 7809895424 md2
    root@NAS326:/home/shares# mdadm --examine /dev/sd[ab]3
    /dev/sda3:
    Magic : a92b4efc
    Version : 1.2
    Feature Map : 0x0
    Array UUID : 22e1530a:2176e840:8e3215af:cf484bed
    Name : NAS326:2 (local to host NAS326)
    Creation Time : Fri Dec 2 11:08:39 2016
    Raid Level : raid1
    Raid Devices : 2
    Avail Dev Size : 15619790848 (7448.10 GiB 7997.33 GB)
    Array Size : 7809895424 (7448.10 GiB 7997.33 GB)
    Data Offset : 262144 sectors
    Super Offset : 8 sectors
    State : clean
    Device UUID : 37269ca3:ce2c07e8:2ae60b09:d9270c12
    Update Time : Tue Mar 14 19:20:42 2023
    Checksum : 9f2e5ac6 - correct
    Events : 11556
    Device Role : Active device 0
    Array State : AA ('A' == active, '.' == missing)
    mdadm: cannot open /dev/sdb3: No such device or address
  • darekpawel
    Thank you…
