Nr7101 and nebula
Fasty
Fasty Posts: 11 image  Freshman Member
Hi, I have one nr7101 and created an Nebula account. Can I do the same configurations from the Nebula account as when I am logged into the nr7101 through 192.168.1.1? Sometimes I am remote and I would like to make the configurations from Nebula, such as to select "4g" or "5G".
Many thanks in advance,.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,394 image  Zyxel Employee
    Hi there,
    In case, you’d like to remote and make the configurations from Nebula as when you are logged into the NR7101 through 192.168.1.1, please go to Nebula > Mobile router > Live tool > Remote configuration > click Establish
    And then use the IP address and port provided with the Nebula password to log into your router.
    For more information:
    The Nebula NR7101 is registered and managed by Nebula where you can monitor your network at any place, such as checking cellular signal quality, check connected client number, and other device information.
    In addition, devices will auto-upgrade it's firmware to the latest version when available (you can also schedule a time for device to upgrade firmware at Site-wide > Configure > Firmware management)
    Zyxel_Judy
  • Zyxel_Judy
    Hi there,
    Zyxel_Judy
Nebula Tips & Tricks
