Plex on a zyxel nas326?
124»
  • Yolo45
    Yolo45 Posts: 13 image  Freshman Member
     vous devez définir le drapeau
    que signifie ceci ?
  • Yolo45
    bonjour alors comme vous me l'avez indiquer j'ai masqué les extensions maintenant que dois-je faire ?
  • Mijzelf
    Mijzelf Posts: 3,013 image  Guru Member
    When you have disabled the hiding of 'known file types', you should see the .txt or .doc extension of web_prefix, and you can remove it. The file shouldn't have an extension.
  • Yolo45
    je n,'est pas bien compris
  • Mijzelf
    Well, I don't know what to say. The package manager looks for a file admin/zy-pkgs/web_prefix. If it exists, it will use the content as, well, a webprefix to exchange ftp://ftp2.zyxel.com/ . It will not check if there are files which have a similar name, or an extension.
    If Windows Explorer says web_prefix is a text document, it probably has an extension, as AFAIK Explorer doesn't look into the file, only at it's extension. So you have to strip the extension, which you can't do if you can't see it. Open notepad, create a new file, and save it. As long as you can't see it's .txt extension, you have to fiddle with Explorer's settings until you can see it. And then look at web_prefix again.
  • Majinbu85
    Majinbu85 Posts: 2 image  Freshman Member
     @Mijzelf
    Hi I'm following your guide to install plex. I got to the metarepository installation, but now I don't know how to retrieve the plex package. I tried to follow the guide but I didn't understand.
    Im stuck here.
    thanks
  • Mijzelf
    Apparently you succeeded in installing MetaRepository. Next step is updating the package list in the firmware package manager, and installing the 'Plex installer' package.
