NWA50AX blinking orange/green non stop, can not configure it
Hi @xav5822
To better understand the issue, could you please provide more details on how the LED light is blinking? There are different meanings with fast blinking and slow blinking between amber and green light. Fast blinking indicates that the device is booting up while slow blinking indicates that the device setting up connection with NCC.
To learn more about the LED light descriptions, you may navigate to NCC >> Help Center >> Device LED Guide.
Regarding the offline issue, it could be caused by various reasons such as network issues or configuration problems. To troubleshoot the issue, you may refer to the following forum link about what to do if your AP is offline on Nebula.
Kay
Kay
The AP blinks orange/green at 1sec interval, but never gets beyond that point.
even tried ZON utility, which can not find the AP. On a mobile, I can connect to the AP's WIFI but Nebula tells me device is pozered off or network issue
I'm about to return the AP
Hi @xav5822
Could you please check if your AP is in the same subnet as your network adapter? It's important to select the correct network adapter when using the ZON utility to scan your network. Here's a forum that discusses ZON utility that you can refer to:
How to use ZON to configure Zyxel device basic setting? — Zyxel CommunitySince your AP is showing slow blinking between orange/green, it means that the connection to your AP is still unsuccessful in setting up a connection with NCC. In most cases, it’s the TCP/UDP port being blocked by firewall or ISP, recommend you check the firewall policy. We also suggest replacing the DNS setting with the static IP address "8.8.8.8" for resolving all domains for Nebula. For detail information, please refer to this FAQ:
How to check the Cloud Control Status when AP is offline on Nebula? — Zyxel CommunityAdditionally, to better understand your problem, please share the following information:
- What is the firmware version of your AP?
- What is the powered mode for the AP? Power adapter or PoE?
- Can you try accessing your AP's local GUI by IP address (if the ZON utility is unable to scan it, you can find the AP's IP address in your router's DHCP table)? If you can, please access the AP's local GUI and collect the AP's diagnostic file at Maintenance > Diagnostics > click "Collect Now".
Kay
Kay
AP is powered by provided alim
ZON can't find it, whatever network adapter on the pc
DHCP server cant find it
can't get any ip from the AP
can only see the WIFI network but can't connect to it
i'm giving up, having spent too much time for a supposedly plug and play thing
- 3K Nebula
- 230 Nebula Ideas
- 6.6K Security
- 667 USG FLEX H Series
- 359 Security Ideas
- 86 Switch Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 307 Service & License
- 499 News and Release
- 96 Security Advisories
- 5K FAQ
- 89 About Community
- 111 Security Highlight
