NWA50AX blinking orange/green non stop, can not configure it
xav5822
xav5822 Posts: 3 image  Freshman Member
edited November 2023 in Nebula
A brand new NWA50AX keeps blinking orange/green non stop, can not configure it
mob. app says device offline or network issue
tried reset to no avail
Should I trash it ?
  • Zyxel_Kay
    edited March 2023
    Hi @xav5822
    To better understand the issue, could you please provide more details on how the LED light is blinking? There are different meanings with fast blinking and slow blinking between amber and green light. Fast blinking indicates that the device is booting up while slow blinking indicates that the device setting up connection with NCC.
    To learn more about the LED light descriptions, you may navigate to NCC >> Help Center >> Device LED Guide
    Regarding the offline issue, it could be caused by various reasons such as network issues or configuration problems. To troubleshoot the issue, you may refer to the following forum link about what to do if your AP is offline on Nebula.
    Kay
    Kay
  • xav5822
    The AP blinks orange/green at 1sec interval, but never gets beyond that point.
    even tried ZON utility, which can not find the AP. On a mobile, I can connect to the AP's WIFI but Nebula tells me device is pozered off or network issue
    I'm about to return the AP
  • Zyxel_Kay
    edited March 2023
    Hi @xav5822
    Could you please check if your AP is in the same subnet as your network adapter? It's important to select the correct network adapter when using the ZON utility to scan your network. Here's a forum that discusses ZON utility that you can refer to:
    How to use ZON to configure Zyxel device basic setting? — Zyxel Community
    Since your AP is showing slow blinking between orange/green, it means that the connection to your AP is still unsuccessful in setting up a connection with NCC. In most cases, it’s the TCP/UDP port being blocked by firewall or ISP, recommend you check the firewall policy. We also suggest replacing the DNS setting with the static IP address "8.8.8.8" for resolving all domains for Nebula. For detail information, please refer to this FAQ:
    How to check the Cloud Control Status when AP is offline on Nebula? — Zyxel Community
    Additionally, to better understand your problem, please share the following information:
    1. What is the firmware version of your AP?
    2. What is the powered mode for the AP? Power adapter or PoE?
    3. Can you try accessing your AP's local GUI by IP address (if the ZON utility is unable to scan it, you can find the AP's IP address in your router's DHCP table)? If you can, please access the AP's local GUI and collect the AP's diagnostic file at Maintenance > Diagnostics > click "Collect Now".  local GUI_diagnostic file.png
    Kay
    Kay
  • xav5822
    AP is powered by provided alim
    ZON can't find it, whatever network adapter on the pc
    DHCP server cant find it
    can't get any ip from the AP
    can only see the WIFI network but can't connect to it
    i'm giving up, having spent too much time for a supposedly plug and play thing
  • Zyxel_Kay
    Hi @xav5822
    Based on your latest update, it seems your AP is abnormal. We recommend reaching out to your vendor to initiate the RMA process . Thank you for your patience and understanding. 😀
    Kay
    Kay
Nebula Tips & Tricks
