Challenges while installing MetaRepository on NSA320s
2»
  • hacko
    hacko Posts: 2 image  Freshman Member
    I have the same issue with a NSA325 FW 4.81 and can provide the details you have.
    What really looks strange are the .list files. It first contains package names, then part of a version, part of an url and then the file names. Furthermore the first package is without indendation. Looks pretty strange but idk what it should look like. Do you need more information?
    cat request | sh -x pkgcgi.cgi inetd-server > out.log
    dirname pkgcgi.cgi
    RELDIR=.
    CONFIG=/usr/local/zy-pkgs/etc/MetaRepository.conf
    . /usr/local/zy-pkgs/etc/MetaRepository.conf
    SCRATCH=/i-data/md0/admin/zy-pkgs/MetaRepository
    LISTEN_AT=59999
    NOPASV=false
    NOCURL=false
    cat
    '[' inetd-server = inetd-server ']'
    ParseInput
    '[' -f /tmp/MetaRepository.log ']'
    local request=
    read line
    '[' ' ' '>' 'GET /NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz HTTP/1.0' ']'
    echo GET /NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz HTTP/1.0
    grep HTTP
    grep GET
    awk '{print $2}'
    request=/NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz
    echo /NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz
    sed 's|/../|/|g'
    read line
    '[' /NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz '!=' '' ']'
    InvokeEngine /NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz
    dirname /NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz
    local path=/NSA325-v2/4.80/zypkg
    basename /NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz
    local file=ZYPKG_INFO.tgz
    '[' ZYPKG_INFO.tgz = ZYPKG_INFO.tgz ']'
    ZYPKG_INFO_tgz /NSA325-v2/4.80/zypkg
    exec
    out.log
    reada /i-data/md0/admin/zy-pkgs/MetaRepository/http___zyxel.diskstation.eu_Users_Mijzelf_zypkg-repo_fw4_stock_packages_/i-data/md0/admin/zy-pkgs/ZYPKGS
    reada /i-data/md0/admin/zy-pkgs/MetaRepository/http___zyxel.diskstation.eu_Users_Mijzelf_zypkg-repo_fw4_/i-data/md0/admin/zy-pkgs/ZYPKGS
    HTTP/1.0 200 OK
    Cache-Control: private
    Server: bash/2.0
    Connection: Close
    Content-type: application/gzip �� d�Wmo�6�g����mbJ�%���lC…
  • Mijzelf
    Mijzelf Posts: 3,074 image  Guru Member
    OK, found it. For some reason the new server does unix<>dos translation when using ftp. And so the ZYPKGS were screwed up.
    It should work now. If it still doesn't, remove the contents of \\<nas>\admin\zy-pkgs\MetaRepository\ and retry.
  • hacko
    edited March 2023
    Awesome! That did the trick, thank you.
    I needed to remove the admin/zy-pkgs/MetaRepository, disable and enable the MetaRepository and fetch Package List twice. Then all the packages were available.
    Thank you, for your passion!
  • kemes
    kemes Posts: 11 image  Freshman Member
    Thank you Mijzelf for solving the issue!
