Challenges while installing MetaRepository on NSA320s
I have the same issue with a NSA325 FW 4.81 and can provide the details you have.
What really looks strange are the .list files. It first contains package names, then part of a version, part of an url and then the file names. Furthermore the first package is without indendation. Looks pretty strange but idk what it should look like. Do you need more information?
cat request | sh -x pkgcgi.cgi inetd-server > out.log
dirname pkgcgi.cgi
RELDIR=.
CONFIG=/usr/local/zy-pkgs/etc/MetaRepository.conf
. /usr/local/zy-pkgs/etc/MetaRepository.conf
SCRATCH=/i-data/md0/admin/zy-pkgs/MetaRepository
LISTEN_AT=59999
NOPASV=false
NOCURL=false
cat
'[' inetd-server = inetd-server ']'
ParseInput
'[' -f /tmp/MetaRepository.log ']'
local request=
read line
'[' ' ' '>' 'GET /NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz HTTP/1.0' ']'
echo GET /NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz HTTP/1.0
grep HTTP
grep GET
awk '{print $2}'
request=/NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz
echo /NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz
sed 's|/../|/|g'
read line
'[' /NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz '!=' '' ']'
InvokeEngine /NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz
dirname /NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz
local path=/NSA325-v2/4.80/zypkg
basename /NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz
local file=ZYPKG_INFO.tgz
'[' ZYPKG_INFO.tgz = ZYPKG_INFO.tgz ']'
ZYPKG_INFO_tgz /NSA325-v2/4.80/zypkg
execout.log reada /i-data/md0/admin/zy-pkgs/MetaRepository/http___zyxel.diskstation.eu_Users_Mijzelf_zypkg-repo_fw4_stock_packages_/i-data/md0/admin/zy-pkgs/ZYPKGS
reada /i-data/md0/admin/zy-pkgs/MetaRepository/http___zyxel.diskstation.eu_Users_Mijzelf_zypkg-repo_fw4_/i-data/md0/admin/zy-pkgs/ZYPKGS
HTTP/1.0 200 OK
Cache-Control: private
Server: bash/2.0
Connection: Close
Content-type: application/gzip �� d�Wmo�6�g����mbJ�%���lC…0 -
OK, found it. For some reason the new server does unix<>dos translation when using ftp. And so the ZYPKGS were screwed up.
It should work now. If it still doesn't, remove the contents of \\<nas>\admin\zy-pkgs\MetaRepository\ and retry.
Awesome! That did the trick, thank you.
I needed to remove the admin/zy-pkgs/MetaRepository, disable and enable the MetaRepository and fetch Package List twice. Then all the packages were available.
Thank you, for your passion!
Thank you Mijzelf for solving the issue!
- 441 Beta Program
- 293 Service & License
- 461 News and Release
