ZyXEL 5101 NR
beatus
beatus Posts: 7 image  Freshman Member
edited January 2024 in Mobile Broadband
Normally, my zyxel 5101 has three LEDs on: green - blue - green, and they are on constantly.  From time to time the blue LED starts to flash incessantly, which I can only stop by logging into the web interface and making any change in the configuration.
What is the reason for the blinking of the BLUE LED?
«1
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    Hello @beatus
    According to the NR5101 user guide I have just downloaded from https://support.zyxel.eu/hc/en-us/articles/4403365084818-Advanced-Downloads-for-5G-devices there should not ever be a flashing blue LED.
         - Blue should only ever appear solid on an LED according to table 2 of the user guide.
    Can you please say which LED is flashing Blue?
    Can you also please say which firmware release you have?
          - something might have changed, but I cannot see the release notes.
    Kind regards,
         Tony
  • beatus
    Hello @beatus
    Kind regards,
         Tony
    The second LED from left is flashing blue
    The router is running V1.00(ABVC.4)C0
  • beatus
    The second LED is flashing blue
    Router runs V1.00(ABVC.4)C0
  • beatus
  • tonygibbs16
    Hello @beatus
    Blue on the Internet LED means connected to a 5G network.
    Does it flash on and off, or between Blue and Green?
         - Green on the Internet LED would mean connected to 3G/4G.
         - Blinking Green would mean a new SMS message.
    Kind regards,
         Tony
  • beatus
    Lot’s of question Tony…..
    As I said already it is FLASHING ON and OFF
    not between Blue and Green
    And I know, that green means new SMS
    Once again for you: it is flashing BLUE ON and OFF
  • Arapaima
    Arapaima Posts: 3 image  Freshman Member
    I'm also jumping in. Mine NR5101 also blinking blue. According to the manual there is no mention of blinking blue light?
  • beatus
    Seems nobody at Zyxel is aware of this and unable to help
  • Arapaima
    I have submitted a support ticket at ZyXEL for more information.
  • Arapaima
    Got a response from Zyxel support with this answer:
    On checking the issue with the blinking like refers to either low signal (which doesn't necessarily need low speed) or a issue with the simcard.
