Zyxel USG Flex 100 no connection to wan and lan
Hi @BLS_Philippines ,
Greeting Forum, Did you have serial console cable ?
Please kindly share your output. or we can have remote session to check this issue.
Thank you
Are you pressing the reset in as the USG is on?
Yes it is on.
Thanks your reply, We need to clarify the current status of the device through the console.
We can have remote session to assist you. Thank you
Zyxel_KevinPosts:353Master MemberApril 11Hi@BLS_Philippines,Thanks your reply, We need to clarify the current status of the device through the console.We can have remote session to assist you. Thank youSir Kevin the problem is I cannot connect to the Zyxel firewall via LAN
Let me provide first the console cable. Thank you.
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
