ZyXEL 5101 NR
beatus
Normally, my zyxel 5101 has three LEDs on: green - blue - green, and they are on constantly. From time to time the blue LED starts to flash incessantly, which I can only stop by logging into the web interface and making any change in the configuration.
What is the reason for the blinking of the BLUE LED?
Hello @beatus
According to the NR5101 user guide I have just downloaded from https://support.zyxel.eu/hc/en-us/articles/4403365084818-Advanced-Downloads-for-5G-devices there should not ever be a flashing blue LED.
- Blue should only ever appear solid on an LED according to table 2 of the user guide.
Can you please say which LED is flashing Blue?
Can you also please say which firmware release you have?
- something might have changed, but I cannot see the release notes.
Kind regards,
Tony0 -
tonygibbs16 said:Hello @beatus
Kind regards,
Tony
The router is running V1.00(ABVC.4)C0
The second LED is flashing blue
Router runs V1.00(ABVC.4)C0
Hello @beatus
Blue on the Internet LED means connected to a 5G network.
Does it flash on and off, or between Blue and Green?
- Green on the Internet LED would mean connected to 3G/4G.
- Blinking Green would mean a new SMS message.
Kind regards,
Tony0 -
Lot’s of question Tony…..
As I said already it is FLASHING ON and OFF
not between Blue and Green
And I know, that green means new SMS
Once again for you: it is flashing BLUE ON and OFF1 -
I'm also jumping in. Mine NR5101 also blinking blue. According to the manual there is no mention of blinking blue light?
Seems nobody at Zyxel is aware of this and unable to help
I have submitted a support ticket at ZyXEL for more information.
Got a response from Zyxel support with this answer:
On checking the issue with the blinking like refers to either low signal (which doesn't necessarily need low speed) or a issue with the simcard.1
- 415 Beta Program
- 2.5K Nebula
- 152 Nebula Ideas
- 101 Nebula Status and Incidents
- 5.8K Security
- 296 USG FLEX H Series
- 281 Security Ideas
- 1.5K Switch
- 77 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 254 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 76 Security Highlight
