Zyxel USG Flex 100 no connection to wan and lan
Hi @BLS_Philippines ,
Greeting Forum, Did you have serial console cable ?
Please kindly share your output. or we can have remote session to check this issue.
Thank you
Are you pressing the reset in as the USG is on?
Yes it is on.
Thanks your reply, We need to clarify the current status of the device through the console.
We can have remote session to assist you. Thank you
Zyxel_Kevin
353
April 11
Hi
@BLS_Philippines
Sir Kevin the problem is I cannot connect to the Zyxel firewall via LAN
Let me provide first the console cable. Thank you.
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 6.3K Security
- 486 USG FLEX H Series
- 320 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 452 News and Release
- 4.3K FAQ
- 93 Security Highlight
