how to open LTE3301-PLUS router case?
SiSZyComm
no joke!
i've inserted my micro sim card into the designated slot. But if you look closely, there is a small gap between the sim card holder and the encasing - and i managed to slide the sim card into that small gap - and it vanished into the router case!
So my sim card is inside the router case. How do I open that router?
There are 4 small screws beneath the rubbery stands.
on the bottom side around 1 inch / 2.5cm from the corner you see a small triangle sign. Could mark a special position. But i have no clue what it marks or where it points to.
tldr;
how do I open a LTE3301-PLUS router case?
I would suggest you dont open the case.
Because opening the case might violate the warranty rule.
Ask for the offical repair access.0
- 3K Nebula
- 228 Nebula Ideas
- 130 Nebula Status and Incidents
- 6.6K Security
- 648 USG FLEX H Series
- 357 Security Ideas
- 86 Switch Ideas
- 55 Wireless Ideas
- 7.1K Consumer Product
- 304 Service & License
- 496 News and Release
- 94 Security Advisories
- 5K FAQ
- 89 About Community
- 110 Security Highlight
