NR7101 no 5G
Hi!
I just purchased the NR7101 to be used on the Telia network here in Norway, and I just cannot get it to connect to 5G. I've installed the lastest firmware and module firmware, and tried what @SELBERG suggests in this thread:
Does anyone have any ideas about what I could do to fix this?
Thanks,
Sven
You live in a 5G area? Your phone connect to 5G?
Yes:) My iPhone 14 Pro just tested 5G speeds of 1016/78Mbps.
Sven
And if you put sim from phone in your 7101?
Switched SIMs, and I have 5G from 7101!👍 (and iPhone with data SIM now only has 4G)
However, 5G speeds from 7101 are nothing close to my iPhone speeds. Just measured download speed of around 60Mbps, which is like 17 times slower than iPhone speeds. Upload is slightly better though..
First of all i think you need a new sim then… Go to Network settings/Broadband/Cellular band and uncheck band auto selection, add just these bands and try again. DON´T FORGET TO HIT APPLY.
Tried the settings above now. Getting the same speeds as with everything on auto. RSRP: -84 dBm
If you do a 5G scan, what will the result be like?
Sorry, I'm afraid I don't know how to do a 5G scan, or even what that really is..
The NR7101 is directional so if speeds are slower than your phone I'd hazard a guess it isn't pointing in the correct direction. Or it is pointing to a cell tower that is too far away or over subscribed. Did you use the Zyxel Air app to align the NR7101 to the strongest signal / cell tower?
I have an RSRP of -83dBm and connect to a cell tower 4KM away. I can achieve 2-400Mbps down and 40-70Mbps up. All depends on what Bands the router connects with.
What are your other stats like (i.e. SINR, etc)?
Thanks.
https://support.zyxel.eu/hc/en-us/articles/4407687743250-LTE-NR-5G-Issues-Zyxel-vs-Provider-Issues
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
